[GRASS-dev] Re: [GRASS GIS] #354: v.out.ogr: bad DB read for
format=GPX
trac at osgeo.org
Sun Nov 9 02:18:43 EST 2008
#354: v.out.ogr: bad DB read for format=GPX
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords: v.out.ogr GPX
Platform: Linux | Cpu: x86-32
Comment (by hamish):
patch to v.out.ogr added to ticket. It populates OGR table using correct
OGR field index, not GRASS's DB column order.
todo:
- clear data columns (need to open Table/cursor or move that
functionality into top of population loop.
- verify the removal of keyval doesn't hurt anything (e.g. case
insensitive column names)
- test, test, test (breaking shapefile output would be bad..)
please test,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/354#comment:8>
