[GRASS-dev] ubuntu 8.10 compile error
Moritz Lennert
mlennert at club.worldonline.be
Wed Nov 12 12:08:46 EST 2008
On 12/11/08 17:58, Isaac Ullah wrote:
> Hi Glynn, Thanks for the advice, it was partially successful. I was
> indeed missing the wx-gtk2 dev package (I had the wx-base dev package,
> so as a lesson to others, be very careful when searching through the
> ubuntu package repository!), and this allowed the NVIS compile error to
> resolve itself. I am still getting compile erros for
> "...gui/wxpython/vdigit", albeit a different error than I was getting
> before. Here is the text of the error:
> /usr/bin/ld: cannot find -lgdi
> collect2: ld returned 1 exit status
> make: *** [OBJ.i686-pc-linux-gnu/_grass6_wxvdigit.so] Error 1
Typing 'grass lgdi' in google brings up tons of messages with the
response, which also is in the relevant directory of the source code
(gui/wxpython/README):
"First, create a symlink to _gdi_.so shared library
$ sudo ln -s `locate _gdi_.so` /usr/local/lib/libgdi.so
e.g.
$ sudo ln -s
/usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so
Then update LD_LIBRARY_PATH or add '/usr/local/lib' to /etc/ld.so.conf
(in this case run 'sudo ldconfig').
Then you can compile the driver."
Moritz
