[GRASS-dev] Re: [GRASS GIS] #31: NVIZ issues in GRASS6.x
GRASS GIS trac at osgeo.org
Sat Nov 15 10:20:48 EST 2008
  Reporter:  clerici      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  major        |   Milestone:  6.4.0
 Component:  NVIZ         |     Version:  6.2.3
Resolution:               |    Keywords:  nviz
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by marisn):
  * platform:  => Unspecified
  * cpu:  => Unspecified
  * summary:  NVIZ  in GRASS6.2.3 (some problems) => NVIZ  issues in
              GRASS6.x
Comment:
 Status update:[[BR]]
 3) Surface mask value still doesn't work with "fine" surface;[[BR]]
 4) As I understood from ogsf code, constant will not work with emission.
 Changed GUI to reflect that (r34297);[[BR]]
 5) Transparency is still a issue;[[BR]]
 6) Vector point/line drawing with new panel layout is a mess. It should
 support following modes:[[BR]]
 a) 3D vector (use Z from vector);[[BR]]
 b) Flat (display on plane, Z is user defined);[[BR]]
 c) Display on surface (Z is taken from surface);[[BR]]
 d) Offset slider (Z in a;b;c is adjusted by offset value).[[BR]]
Ticket URL: <http://trac.osgeo.org/grass/ticket/31#comment:5>
