[GRASS-dev] Re: [GRASS GIS] #364: Compiling QGIS from svn has a compiler error related to GRASS api
GRASS GIS trac at osgeo.org
Sun Nov 16 12:40:58 EST 2008
  Reporter:  cgsbob   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:
  Platform:  Linux    |         Cpu:  x86-64
Comment (by cgsbob):
 After a little digging I found the problem...see
 http://trac.osgeo.org/grass/changeset/34288#file2.  Since this api change
 is intentional, it seems like QGIS would have to change?
 Btw, the problem line in QGIS looks like this:
     Vect_build( map.map, stderr );
Ticket URL: <http://trac.osgeo.org/grass/ticket/364#comment:1>
