[GRASS-dev] [GRASS GIS] #364: Compiling QGIS from svn has a
compiler error related to GRASS api
trac at osgeo.org
Sun Nov 16 12:05:56 EST 2008
#364: Compiling QGIS from svn has a compiler error related to GRASS api
Reporter: cgsbob | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
Compiling QGIS 1.0 Preview 2 with Grass 6.4.svn on X86_64 Ubuntu Hardy
Heron system gives me this compiler error:
[ 64%] Building CXX object
src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o
/usr/local/grass-6.4.svn/include/grass/Vect.h: In static member function
‘static int QgsGrassProvider::openMap(QString, QString, QString,
QString)’:
/usr/local/grass-6.4.svn/include/grass/Vect.h:197: error: too many
arguments to function ‘int Vect_build(Map_info*)’
/home/bobm/src/gis/qgis_svn/src/providers/grass/qgsgrassprovider.cpp:1043:
error: at this point in file
/usr/local/grass-6.4.svn/include/grass/Vect.h: In member function
‘bool QgsGrassProvider::closeEdit(bool)’:
/usr/local/grass-6.4.svn/include/grass/Vect.h:199: error: too many
arguments to function ‘int Vect_build_partial(Map_info*, int)’
/home/bobm/src/gis/qgis_svn/src/providers/grass/qgsgrassprovider.cpp:1522:
/home/bobm/src/gis/qgis_svn/src/providers/grass/qgsgrassprovider.cpp:1523:
make[2]: ***
[src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o] Error 1
make[1]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/all] Error 2
I've already contacted the QGIS devs and they say it is likely a Grass
problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/364>
