[GRASS-dev] Re: [GRASS GIS] #367: g.region segmentation violation
when creating EPSG:4326 location
trac at osgeo.org
Mon Nov 17 17:03:13 EST 2008
#367: g.region segmentation violation when creating EPSG:4326 location
Reporter: epatton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords: g.region, segmentation fault
Platform: Linux | Cpu: x86-64
Comment (by marisn):
Running "g.region -p" from the command line gives "segmentation fault"
is the real root of problem.
Let me guess - Ubuntu? Install newer GDAL version and then svn up && make
distclean && make
Otherwise - gdb g.region; run; bt.
Ticket URL: <http://trac.osgeo.org/grass/ticket/367#comment:1>
