[GRASS-dev] Re: [GRASS GIS] #367: g.region segmentation violation
when creating EPSG:4326 location
trac at osgeo.org
Tue Nov 18 11:25:42 EST 2008
#367: g.region segmentation violation when creating EPSG:4326 location
Reporter: epatton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords: g.region, segmentation fault
Platform: Linux | Cpu: x86-64
Comment (by epatton):
Thanks. I've removed the Ubuntu versions of geos, proj and gdal, and
compiled each of those from source. No errors during configure or make for
any of them.
Grass configure proceeds fine, and I can confirm that proj and gdal are
installed. I get a ton of make errors, with about 30 modules failing. The
first in the error.log is /usr/local/grass6_devel/lib/proj; here's the
error I get when I change to this directory and run make clean and then
'make':
/usr/bin/ld: /usr/local/lib/libgdal.a(cpl_conv.o): relocation R_X86_64_32S
against `std::basic_string<char, std::char_traits<char>,
std::allocator<char> >::_Rep::_S_empty_rep_storage' can not be used when
making a shared object; recompile with -fPIC
/usr/local/lib/libgdal.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make: *** [/usr/local/grass6_devel/dist.x86_64-unknown-linux-
gnu/lib/libgrass_gproj.6.4.svn.so] Error 1
Here is the Grass configure statement:
CFLAGS="-g -Wall -fPIC"
./configure \
--enable-64bit \
--with-libs=/usr/lib64 \
--with-tcltk-includes=/usr/include/tcl8.5 \
--without-postgres \
--with-sqlite \
--with-sqlite-includes=/usr/include \
--with-freetype \
--with-readline \
--with-cxx \
--with-gdal \
--with-gdal-includes=/usr/local/include \
--enable-largefile \
--with-proj \
--with-proj-share=/usr/local/share/proj \
--with-proj-lib=/usr/local/lib \
--with-fftw \
--with-fftw-includes=/usr/include \
--with-fftw-libs=/usr/lib \
--with-python \
--with-opengl \
--with-opengl-includes=/usr/include/GL \
--with-python=yes \
--with-python-includes=/usr/bin/ \
--with-wxwidgets=yes \
--with-cairo \
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/367#comment:2>
