[GRASS-dev] Re: [GRASS GIS] #364: Compiling QGIS from svn has a
compiler error related to GRASS api
trac at osgeo.org
Mon Nov 17 20:46:14 EST 2008
#364: Compiling QGIS from svn has a compiler error related to GRASS api
Reporter: cgsbob | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: fixed | Keywords:
Platform: Linux | Cpu: x86-64
Comment (by hamish):
Replying to [comment:8 glynn]:
> What's the situation with grass-addons? Is there a specific
> release or branch which they are supposed to be compatible with,
> or does it vary from module to module?
AFAIK they are all grass 6.x, some of them use newer things like
g.message, others not. Porting between grass 6.x should be trivial,
so IMO there is no need to break it up further than it is.
I have just created grass5/ and grass7/ dirs, and eventually the
current root dirs should be moved into a grass6/. Hopefully the
presence of the new dirs should make it obvious to commiters where they
should be putting stuff.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/364#comment:11>
