[GRASS-dev] Re: [GRASS GIS] #364: Compiling QGIS from svn has a
compiler error related to GRASS api
trac at osgeo.org
Tue Nov 18 01:21:47 EST 2008
#364: Compiling QGIS from svn has a compiler error related to GRASS api
Reporter: cgsbob | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: fixed | Keywords:
Platform: Linux | Cpu: x86-64
Comment (by cgsbob):
I just updated r9656, but I'm still having problems. I've attached to
this ticket my hard coded fix. I can not find where GRASS_VERSION_MAJOR
and GRASS_VERSION_MINOR are defined in qgis, so I added them to each
problem file.
Replying to [comment:10 jef]:
> and https://trac.osgeo.org/qgis/changeset/9656 should be the correct fix
pointing to the right TRAC.
Ticket URL: <http://trac.osgeo.org/grass/ticket/364#comment:12>
