[GRASS-dev] Re: raster modules still using sites library
Michael Barton
michael.barton at asu.edu
Tue Nov 18 14:31:02 EST 2008
Thanks Colin,
I'll need to try more to see what is going on.
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Nov 18, 2008, at 12:26 PM, Colin Nielsen wrote:
> I'm not sure what version you are using but those modules run fine for
> me using a vector file, with multiple points (I've been using v6.3
> compiled in windows with msys/mingw). They just put up a warning
> message about the sites library being deprecated. Honestly, I
> attempted but failed to update r.walk to the vector library. My
> programming skills are not quite up to par, yet.
> -Colin
> On Tue, Nov 18, 2008 at 2:17 PM, Michael Barton <michael.barton at asu.edu
> > wrote:
>> For several years now, r.cost, r.drain, and now r.walk have
>> continued to use
>> the adapted sites library instead of the vector library. This means
>> that
>> they all fail if you enter vector points as starting points. It
>> sure would
>> be nice if this feature actually worked on these so that you could
>> 1) use a
>> vector map for start points rather than having to manually enter
>> coordinates
>> and 2) use multiple starting points.
>> Michael
>> USA
