[GRASS-dev] gettext: accumulation of unrelated messages in .po
file bottom
Glynn Clements
glynn at gclements.plus.com
Tue Nov 18 17:23:35 EST 2008
Markus Neteler wrote:
> I observe that more and more messages are accumulated
> without file/line reference in the bottom of the .po files.
> I wonder
> - how come?
> - can we remove it as junk (manually??)?
Looking at the messages, I think that these correspond to strings
which no longer occur in the source code.
E.g. looking at the bottom of grasslibs_de.po in 7.0, there are a lot
of messages which relate to display monitors, or appear to be prompts
for interaction.
Also, amongst the first such messages are:
msgid "G_malloc: out of memory"
msgstr "G_malloc: Kein Speicher mehr da."
msgid "G_calloc: out of memory"
msgstr "G_calloc: Kein Speicher mehr da."
msgid "G_realloc: out of memory"
msgstr "G_realloc: Kein Speicher mehr da."
The error messages were recently changed to specify the number of
bytes along with the source file and line number of the caller.
I suggest that unused messages are retained for reference. If a
message is only changed slightly, e.g. by adding additional text, the
new translation should avoid unnecessary changes.
