[GRASS-dev] r.watershed lsfac
Helena Mitasova
hmitaso at unity.ncsu.edu
Tue Nov 18 23:36:20 EST 2008
the man page for r.watershed says that the lsfac is multiplied by
100, but the result is DCELL
so I am wondering whether the multiplication is still true. (and if
yes whether it should be changed)
And how is this for the new r.watershed2?
thanks,
Helena
On Oct 30, 2008, at 2:17 PM, Glynn Clements wrote:
> Helena Mitasova wrote:
>> I have commented out the sites-related input/output from simwe in
>> trunk.
>> It compiles and runs with grass7 updated today - I tested it with the
>> examples from grassbook and some variations of the parameters.
>> Are these changes enough to get it back into grass7?
>> (there is still the issue of 3 separate waterglobs.h - I need to talk
>> to Jaro to see what would be the best way to fix it).
> I suggest committing the changes, but leaving it disabled in
> raster/Makefile until the sites and waterglobs.h issues have been
> fully dealt with.
> If you keep a private copy around for too long, it may become
> problematic to merge it if the SVN copy gets modified in the meantime
> (if I'm making changes related to a particular header file or a
> particular function, I'll normally change everything which uses it,
> even modules which are disabled).
> Regarding waterglobs.h, does it work if you remove
> r.sim.*/waterglobs.h and add -I../simlib to EXTRA_CFLAGS in
> r.sim.*/Makefile? Or are there other issues?
>> Also, should I submit these changes to GRASS64 so that it runs in
>> winGRASS? (I am not sure what was the problem there)
> I'd suggest leaving it for now. The version in 6.4 isn't as likely to
> be modified as in 7.0.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
