[GRASS-dev] g.mlist: exclude parameter wish
Huidae Cho grass4u at gmail.com
Wed Nov 19 21:37:49 EST 2008
Markus,
We could add the exclude option, but I'm not so sure if we really need it.
You can solve your problem by using a more specific wildcard if Paul's
trick doesn't work.
pat="gpcp_1dd_p1d_[0-9][0-9][0-9][0-9]_count"
It's a little lengthy, but it works.  Any better examples where we might
want the exclude option?
Huidae
On Wed, Nov 19, 2008 at 12:40:52PM +0100, Markus Neteler wrote:
> On Wed, Nov 19, 2008 at 11:12 AM, Hamish <hamish_b at yahoo.com> wrote:
> > Markus wrote:
> >> g.mlist type=rast patt="gpcp_1dd_p1d_*_count"
> >> exclude="month"
> >> gpcp_1dd_p1d_1997_count
> >> gpcp_1dd_p1d_1998_count
> >> gpcp_1dd_p1d_1999_count
> >> gpcp_1dd_p1d_2000_count
> >> gpcp_1dd_p1d_2001_count
> >> gpcp_1dd_p1d_2002_count
> >> gpcp_1dd_p1d_2003_count
> >> gpcp_1dd_p1d_2004_count
> >> gpcp_1dd_p1d_2005_count
> >> gpcp_1dd_p1d_2006_count
> >> gpcp_1dd_p1d_2007_count
> >> I know that -r and -e are available but I failed to write
> >> an exclusion regex.
> >> And often just simple patterns are to be suppressed in the
> >> selection.
> > no idea about the C version, but with the shell script version it would
> > be roughly like
> > if [ -n "$GIS_OPT_EXCLUDE" ] ; then
> >  EXCLD_STR="| grep -v $GIS_OPT_EXCLUDE"
> > else
> >  EXCLD_STR=""
> > fi
> > g.list * ... | ... $EXCLD_STR
> Yes - but I dunno how to implement that in C.
> > do you now use g.mlist | grep -v 'expr' ?
> g.mlist type=rast patt="gpcp_1dd_p1d_*_count"  | grep -v month | tr
> '\n' ',' | sed 's+,$++g
> but that's rather funky for daily usage.
> [for today, Paul's trick helped but the problem will return]
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
