[GRASS-dev] Re: [GRASS GIS] #35: Verify and uncomment Swiss datum
parameters
trac at osgeo.org
Tue Nov 25 02:52:46 EST 2008
#35: Verify and uncomment Swiss datum parameters
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by swisstopoum):
Replying to [comment:7 hamish]:
> > Answer: A 7-parameter transformation is always more accurate
> > than a 3-parameter solution.
> I dare you to say that on the PROJ4 mailing list.
Ok, my mistake. It is only true if you determine the parameters out of the
same data. If you use different data sets you can get any result.
Ticket URL: <http://trac.osgeo.org/grass/ticket/35#comment:8>
