[GRASS-dev] [GRASS GIS] #381: wxgui: Show attribute data depends on
global db connection, not file db connection parameter
trac at osgeo.org
Tue Nov 25 06:04:56 EST 2008
#381: wxgui: Show attribute data depends on global db connection, not file db
Reporter: mlennert | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
When trying to access the attribute table in the wxgui, I get an error
when the map is connected to a table which is not in the default database
of the mapset, in other words v.db.connect gives other information for
database than db.connect. This is because db.tables is called.
Probably attribute management of a single map and table management for the
default database need to be decoupled somehow...
Ticket URL: <http://trac.osgeo.org/grass/ticket/381>
