[GRASS-dev] Re: [GRASS GIS] #381: wxgui: Show attribute data
depends on global db connection, not file db connection parameter
trac at osgeo.org
Fri Nov 28 16:34:37 EST 2008
#381: wxgui: Show attribute data depends on global db connection, not file db
Reporter: mlennert | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by martinl):
Seems to work for me...
db.connect -p
driver:sqlite
database:$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
schema:
group:
v.db.connect bz -g
1 bz cat /home/martin/grassdata/nc_spm_08/sqlite/sqlite.db sqlite
2 bz1 cat /home/martin/grassdata/nc_spm_08/sqlite/sqlite.db sqlite
3 p cat grass_test pg
No problem to display attribute data of 'bz' vector map in wxGUI.
'db.tables' is called on line 2460 in 'dbm' module with 'driver' and
'database' parameters. So I don't see any problem. Please correct me.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/381#comment:1>
