[GRASS-dev] Re: [GRASS GIS] #381: wxgui: Show attribute data
depends on global db connection, not file db connection parameter
trac at osgeo.org
Sat Nov 29 12:21:03 EST 2008
#381: wxgui: Show attribute data depends on global db connection, not file db
Reporter: mlennert | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by mlennert):
Replying to [comment:1 martinl]:
> Seems to work for me...
> db.connect -p
> driver:sqlite
> database:$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
> schema:
> group:
> v.db.connect bz -g
> 1 bz cat /home/martin/grassdata/nc_spm_08/sqlite/sqlite.db sqlite
> 2 bz1 cat /home/martin/grassdata/nc_spm_08/sqlite/sqlite.db sqlite
> 3 p cat grass_test pg
> No problem to display attribute data of 'bz' vector map in wxGUI.
'db.tables' is called on line 2460 in 'dbm' module with 'driver' and
'database' parameters. So I don't see any problem. Please correct me.
IIUC, your map is connected to the database which is the default database
of the mapset ($GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db - assuming that
you are in location nc_spm_08 and mapset sqlite). The problem I saw was
when the map was connected to a database (and driver) different from the
default setting. I'll try to come up with a reproducible scenario, but
that won't be before Monday.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/381#comment:2>
