[GRASS-dev] Re: [GRASS GIS] #381: wxgui: Show attribute data depends on global db connection, not file db connection parameter
GRASS GIS trac at osgeo.org
Sat Nov 29 12:29:02 EST 2008
  Reporter:  mlennert     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  major        |   Milestone:  6.4.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by martinl):
 > IIUC, your map is connected to the database which is the default
 database of the mapset ($GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db -
 assuming that you are in location nc_spm_08 and mapset sqlite). The
 problem I saw was when the map was connected to a database (and driver)
 different from the default setting. I'll try to come up with a
 reproducible scenario, but that won't be before Monday.
 in my case, the third attribute table comes from PostgreSQL database.
Ticket URL: <http://trac.osgeo.org/grass/ticket/381#comment:3>
