[GRASS-dev] [GRASS GIS] #382: r.texture NULL or negative value
ERROR (possible r.null problem)
trac at osgeo.org
Tue Nov 25 15:33:56 EST 2008
#382: r.texture NULL or negative value ERROR (possible r.null problem)
Reporter: khufkens | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.3.1
Component: Raster | Version: 6.3.0
Keywords: r.texture r.null ERROR null negative values | Platform: Linux
Cpu: Unspecified |
Concerning r.texture in GRASS 6.3:
Running r.texture on a map after r.null (should have) replaced all NULL
values still produces an error indicating a persistent NULL or negative
value in the map.
r.category shows no NULL values or negative values but yet they are there
for r.texture...
Adding a fixed value to the map with the map calculator or running a
running window analysis removes these hidden values and also removes the
error.
This traces back to either an error in r.texture or r.null, not sure...
Ticket URL: <http://trac.osgeo.org/grass/ticket/382>
