[GRASS-dev] testing results of r.watershed2 against old r.watershed
Hamish hamish_b at yahoo.com
Fri Nov 28 00:49:54 EST 2008
Markus:
> > I have moved the code to GRASS 6.4.svn and 7.svn now and deactivated
> > the old version.
Glynn:
> And presumably the clean-up I've done on watershed in 7.0 has all now
> been discarded?
.... not fully - in devbr6 modifications need to me made to r.watershed2
to keep the old option names:
-    opt15->key = "slope_steepness";
+    opt15->key = "slope.steepness";
etc. so it has at least some of the grass7 changes.
actually I think it is wrong to call this r.watershed2 at all, really
after whitespace changes etc it is just some normal patches to r.watershed,
not a full rewrite of the module.
As such it should be merged into the old r.watershed code not get its own
new directory. A suggested way forward: indent and modify r.watershed2
so that a minimal diff is created and apply that to r.watershed(1) keeping
an eye on option name changes and new unmerged developments.
And keep the Makefiles pointing at the original.
Hamish
