[GRASS-dev] Re: [GRASS GIS] #385: description for v.db.reconnect.all
GRASS GIS trac at osgeo.org
Sat Nov 29 21:05:20 EST 2008
  Reporter:  nikos        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:2 glynn]:
 > The "parameters" section is generated by running the script
 > with the --html-description option. The text is taken from the
 > corresponding "#% description:" line at the top of the script.
 > I note that the script already has that text; it should be
 > removed. For option descriptions, brevity is more important
 > than exhaustively documenting the option's semantics.
 long description split into shorter #%label: and #%description: in SVN.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/385#comment:3>
