[GRASS-dev] Re: [GRASS GIS] #385: description for v.db.reconnect.all
GRASS GIS trac at osgeo.org
Sun Nov 30 00:28:14 EST 2008
  Reporter:  nikos        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:3 hamish]:
 > > The "parameters" section is generated by running the script
 > > with the --html-description option. The text is taken from the
 > > corresponding "#% description:" line at the top of the script.
 > > I note that the script already has that text; it should be
 > > removed. For option descriptions, brevity is more important
 > > than exhaustively documenting the option's semantics.
 > long description split into shorter #%label: and #%description: in SVN.
 I've just put it back to "Name of old database". Notes, details, caveats
 and the like belong in the manual. The "help" output isn't intended to be
 the complete manual.
Ticket URL: <https://trac.osgeo.org/grass/ticket/385#comment:4>
