[GRASS-dev] fseeko() in libiostream
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Oct 7 18:50:17 EDT 2008
On Tue, 7 Oct 2008, Paul Kelly wrote:
> I'm not sure if this is by design or by accident that it
> works like this but it's quite neat really.
Sorry that was a confusing statement - I meant that the fact that the large
file support in config.h can be activated by #define USE_LARGEFILES 1 is
confusing, as there is also a Makefile variable called USE_LARGEFILES that
is set in the configure script.
> If we get this hammered out properly it can go on
> http://grass.osgeo.org/wiki/Large_File_Support
> Paul
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
