[GRASS-dev] Re: [GRASS-SVN] r33717 - grass/trunk/lib/gis
Glynn Clements
glynn at gclements.plus.com
Tue Oct 7 19:05:06 EDT 2008
Markus Neteler wrote:
> > Author: glynn
> > Date: 2008-10-07 06:01:59 -0400 (Tue, 07 Oct 2008)
> > New Revision: 33717
> > Modified:
> > grass/trunk/lib/gis/null_val.c
> > Log:
> > Make G_is_[fd]_null_value() check for any NaN, not just all-ones
> /me backport this?
Maybe.
Unless there are modules which genuinely need to distinguish GRASS
nulls from other NaNs, the only real risk is a broken compiler
"optimising" the "x != x" test away.
At one time, that was quite likely, but compilers tend to be better
nowadays (i.e. gcc has effectively destroyed the market for half-baked
C compilers).
Although it's a very small risk, if it does break, it's rather
significant.
