[GRASS-dev] compilation success
Glynn Clements
glynn at gclements.plus.com
Wed Oct 8 19:05:17 EDT 2008
Michael Barton wrote:
> When I try the new nviz, I nothing happens visually, but I get the
> following in the layer manager output window.
> import grass6_wxnviz as wxnviz
> File "/Applications/Grass/GRASS-6.4.app/Contents/MacOS/etc
> /wxpython/nviz/grass6_wxnviz.py", line 7, in <module>
> import _grass6_wxnviz
> ImportError
> dynamic module does not define init function
> (init_grass6_wxnviz)
Is gui/wxpython/nviz/grass6_wxnviz_wrap.cpp generated correctly?
It should contain the line:
#define SWIG_init init_grass6_wxnviz
and then the function:
SWIGEXPORT void SWIG_init(void) {
at the bottom of the file.
Are there any errors or warnings from compilation in gui/wxpython/nviz?
Does init_grass6_wxnviz (or anything similar) show up in the output
nm -D OBJ.*/_grass6_wxnviz.so
