[GRASS-dev] compilation success
Michael Barton michael.barton at asu.edu
Thu Oct 9 01:35:08 EDT 2008
With William's recent fix, I got farther tonight on getting a working
wxPython nviz than ever before.
I still have to remove render.c, but otherwise compilation goes well.
When I select nviz from the map display, I now get a message box
saying "Please wait, loading data..." and I get a partial nviz toolbar
(color picker and exit door). Then it sits. In the layer manager
output window, I get the following error.
   File "/Applications/Grass/GRASS-6.4.app/Contents/MacOS/etc
/wxpython/gui_modules/toolbars.py", line 250, in
OnSelectTool
self.mapdisplay.AddToolbar("nviz")
/wxpython/gui_modules/mapdisp.py", line 2758, in AddToolbar
mapWindow=self.MapWindow3D)
/wxpython/gui_modules/nviz_tools.py", line 69, in __init__
self.__createViewPage()
/wxpython/gui_modules/nviz_tools.py", line 158, in
__createViewPage
bind=(self.OnViewChange, self.OnViewChanged,
self.OnViewChangedSpin))
/wxpython/gui_modules/nviz_tools.py", line 1308, in
CreateControl
size=sizeW)
   File "/BinaryCache/wxWidgets/wxWidgets-11~57/Root/System/L
ibrary/Frameworks/Python.framework/Versions/2.5/Extras/lib/p
ython/wx-2.8-mac-unicode/wx/_controls.py", line 2600, in
__init__
wx._core
PyAssertionError
C++ assertion "!(style & wxSL_VERTICAL) || !(style &
wxSL_HORIZONTAL)" failed at ../src/mac/carbon/slider.cpp(98)
in Create(): incompatible slider direction and orientation
Looks like it may be stuck on a bad wxPython widget definition.
Michael
On Oct 8, 2008, at 4:05 PM, Glynn Clements wrote:
> Michael Barton wrote:
>> When I try the new nviz, I nothing happens visually, but I get the
>> following in the layer manager output window.
>> import grass6_wxnviz as wxnviz
>> /wxpython/nviz/grass6_wxnviz.py", line 7, in <module>
>> import _grass6_wxnviz
>> ImportError
>> dynamic module does not define init function
>> (init_grass6_wxnviz)
> Is gui/wxpython/nviz/grass6_wxnviz_wrap.cpp generated correctly?
> It should contain the line:
> 	#define SWIG_init    init_grass6_wxnviz
> and then the function:
> 	SWIGEXPORT void SWIG_init(void) {
> at the bottom of the file.
> Are there any errors or warnings from compilation in gui/wxpython/
> nviz?
> Does init_grass6_wxnviz (or anything similar) show up in the output
> from:
> 	nm -D OBJ.*/_grass6_wxnviz.so
> Glynn Clements <glynn at gclements.plus.com>
