[GRASS-dev] problem compiling grass7
Martin Landa landa.martin at gmail.com
Mon Oct 13 04:52:41 EDT 2008
2008/10/13 Glynn Clements <glynn at gclements.plus.com>:
> I'm not sure why it's failing in this particular case. I don't get any
> errors building that that file (or any other HTML file),
> pngdriver.html hasn't changed in over a month, and I checked for any
> broken HTML files within the last few days. Do you have any local
> modifications?
no, to be sure I have downloaded fresh code from SVN. Now I am getting
    self.fmt(spec, content)
  File "/home/martin/smetiste/grass_trunk/tools/g.html2man/g.html2man.py",
line 229, in fmt
    (pre,sep,post) = format.partition("@")
AttributeError: 'str' object has no attribute 'partition'
I am using python 2.4. Are we going to require python >= 2.5?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
