[GRASS-dev] r.resamp.stats: nulls along western boundary
Mon Oct 13 06:00:17 EDT 2008
Hamish wrote:
> While running through this set of commands to resample from 30" to 2':
>   http://grass.osgeo.org/wiki/Blue_Marble#Processing
> I notice that the output of r.resamp.stats has its western-most raster
> column set to all NULL. The other 3 borders seem to be ok. As the 30"
> data is without NULLs, and the target region is an exact multiple of
> the source region, it doesn't seem to be an inherent
> exceeding-the-border effect. The propagate nulls flag was not used.
Can you come up with a recipe to reproduce this with the standard
example data sets?
