[GRASS-dev] r.series: thresholding?
Glynn Clements
glynn at gclements.plus.com
Wed Oct 15 07:07:06 EDT 2008
Markus Neteler wrote:
> >> would it be possible to add a threshold parameter to r.series?
> > don't know,
> You don't know if you like it or don't know how?
> It seems to be a simple if condition in the core of the
> raster col/row loop.
The usual recommendation here would be to process the source data with
r.mapcalc.
I'm aware that adding this feature to r.series could save a fair
amount of time, given that it is often used on large numbers of maps.
However, the same would be true of just about any such transformation
which could be applied to the input data.
