[GRASS-dev] Re: [GRASS-SVN] r33885 - grass/trunk/include
Wed Oct 15 14:38:01 EDT 2008
Martin Landa wrote:
> > +#define GISPROMPT_COLOR    "old,color,color"
> is it really necessary to recover this macro? It's only one used here.
> If so maybe we should define other standard gisprompts in the similar
> way (e.g. "old,vector,vector", "old_dbcolumn,dbcolumn,dbcolumn",
> etc.).
After it was removed, much of display/d.* failed to compile (30 uses
in 17 modules). Before it can be removed, anything which uses it needs
to be converted to use either an equivalent G_define_standard_option(),
or the literal string.
