[GRASS-dev] Re: [GRASS-SVN] r33885 - grass/trunk/include
Martin Landa
landa.martin at gmail.com
Wed Oct 15 14:41:29 EDT 2008
2008/10/15 Glynn Clements <glynn at gclements.plus.com>:
>> is it really necessary to recover this macro? It's only one used here.
>> If so maybe we should define other standard gisprompts in the similar
>> way (e.g. "old,vector,vector", "old_dbcolumn,dbcolumn,dbcolumn",
>> etc.).
> After it was removed, much of display/d.* failed to compile (30 uses
> in 17 modules). Before it can be removed, anything which uses it needs
> to be converted to use either an equivalent G_define_standard_option(),
> or the literal string.
sorry, I have overlooked that. Anyway, is it better to define
#define GISPROMPT_COLOR "old,color,color"
and other standardized gisprompts in gis.h
or just remove GISPROMPT_COLOR and fix the all modules by using
G_define_standard_option()?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
