[GRASS-dev] r.series: thresholding?
Markus Neteler
neteler at osgeo.org
Thu Oct 16 07:15:12 EDT 2008
On Wed, Oct 15, 2008 at 5:46 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> would it be possible to add a threshold parameter to r.series?
>> In our case, we want to consider only pixels above a certain
>> value (>=).
>> Not sure about the implementation: have two flags to define
>> above/below?
> Implemented in r33886.
> r.series has a new option, range=lo,hi; values outside of this range
> are treated as null (i.e. will be ignored by most aggregates, or will
> cause the result to be null if -n is given).
> The values are FP, so you can use -inf or inf for a single threshold,
> e.g. range=0,inf to ignore negative values.
Excellent & quite helpful. I have slightly expanded the docs,
tested and backported it as r33905 to G6.4.
Markus
