[GRASS-dev] Re: [GRASS GIS] #339: d.mon doesn't work (WinGrass
commandline)
trac at osgeo.org
Mon Oct 20 03:49:37 EDT 2008
#339: d.mon doesn't work (WinGrass commandline)
Reporter: schulzea | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.3.0 RCs
Resolution: fixed | Keywords:
Platform: MSWindows XP | Cpu: Unspecified
Comment (by pkelly):
It shows:
no known monitors
Are you getting at that scripts using "d.mon start=x0" should run d.mon -l
first to check that x0 is available? Sounds very reasonable.
Paul
Ticket URL: <https://trac.osgeo.org/grass/ticket/339#comment:8>
