[GRASS-dev] Re: [GRASS GIS] #339: d.mon doesn't work (WinGrass
commandline)
trac at osgeo.org
Mon Oct 20 03:55:34 EDT 2008
#339: d.mon doesn't work (WinGrass commandline)
Reporter: schulzea | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.3.0 RCs
Resolution: fixed | Keywords:
Platform: MSWindows XP | Cpu: Unspecified
Comment (by hamish):
Replying to [comment:8 pkelly]:
> Are you getting at that scripts using "d.mon start=x0" should run
> d.mon -l first to check that x0 is available? Sounds very
> reasonable.
most of them already check one of d.mon -p -l -L
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/339#comment:9>
