[GRASS-dev] i.ortho.photo
Glynn Clements
glynn at gclements.plus.com
Tue Oct 21 12:47:16 EDT 2008
Re:
r33944 | hamish | 2008-10-21 03:35:40 +0100 (Tue, 21 Oct 2008) | 1 line
remove code based on Vask_lib+Xmons; porting will happen in
develbranch6 then when operational be merged back into grass7 SVN
Isn't this backwards?
There's no need for i.ortho.photo to change in 6.4, as monitors (and
the display architecture generally) won't be changing there.
Also, if you need to write any code which uses the raster/display
libraries, you'll need to substantially modify it in order to get it
working in 7.0.
