[GRASS-dev] Re: [GRASS GIS] #327: v.out.ogr does not export
features when 'dsn' AND 'layer' options are given
trac at osgeo.org
Wed Oct 22 05:27:33 EDT 2008
#327: v.out.ogr does not export features when 'dsn' AND 'layer' options are given
Reporter: dylan | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Resolution: worksforme | Keywords: v.out.ogr
Platform: Linux | Cpu: x86-32
Changes (by mlennert):
* status: new => closed
* resolution: => worksforme
Comment:
As defined in the man page:
layer=integer
Layer number
A single vector map can be connected to multiple database tables. This
number determines which table to use.
Default: 1
So your use of layer is incorrect.
Also, note that the default of type= is 'line,boundary', so if you are
trying to export areas, you will have to explicitly set type=area.
Closing this bug.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/327#comment:1>
