[GRASS-dev] Re: [GRASS GIS] #327: v.out.ogr does not export features when 'dsn' AND 'layer' options are given
Dylan Beaudette debeaudette at ucdavis.edu
Fri Oct 24 20:44:28 EDT 2008
> given
>- Reporter:  dylan       |       Owner:  grass-dev at lists.osgeo.org Type:
> defect      |      Status:  closed
>   Priority:  major       |   Milestone:  6.4.0
>  Component:  Vector      |     Version:  svn-develbranch6
> Resolution:  worksforme  |    Keywords:  v.out.ogr
>   Platform:  Linux       |         Cpu:  x86-32
>- Changes (by mlennert):
>   * status:  new => closed
>   * resolution:  => worksforme
> Comment:
>  As defined in the man page:
>  layer=integer
>      Layer number
>      A single vector map can be connected to multiple database tables. This
>  number determines which table to use.
>      Default: 1
>  So your use of layer is incorrect.
>  Also, note that the default of type= is 'line,boundary', so if you are
>  trying to export areas, you will have to explicitly set type=area.
>  Closing this bug.
>  Moritz
OK-- that was my mistake
thanks,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
