[GRASS-dev] Re: [GRASS GIS] #338: d.vect / v.univar does not work
for layer > 1 ; v.db.join has bugs (corrected here)
trac at osgeo.org
Wed Oct 22 06:01:44 EDT 2008
#338: d.vect / v.univar does not work for layer > 1 ; v.db.join has bugs
(corrected here)
Reporter: aprasad | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: Vector | Version: 6.3.0
Resolution: fixed | Keywords: layers > 1
Platform: MSWindows XP | Cpu: x86-32
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [ticket:338 aprasad]:
> Two bugs:
> 1) d.vect does not work for layer > 1 (blank display)
I cannot confirm this. Can you be more precise, including output of
'v.category [...] option=report' on your map ?
> d.vect.thematic has a bug i.e., does not include the layer option in
v.univar it uses - However, including this option does NOT help ...
BECAUSE v.univar does not work for layers > 1 (gives no values)
Again, I cannot confirm. Same remark as above.
>- so used v.univar.sh which works (since it uses database, driver and
table options - DON'T DEPRECATE IT YET)....BUT THEN, d.vect does not work
for layers > 1 (blank display) - which is used by d.vect.thematic.
v.univar.sh is different in that it is not linked to a specific vector map
(its man page is misleading in that sense), you can use it to interrogate
any column of any table in any database supported by grass, but no need
for any link to specific maps.
> 2) v.db.join: The layer option was missing in v.db.addcol and, in
db.execute, 'driver' and 'database' options were missing thus breaking it
for layer > 1
Fixed in Revision 33971.
> NOTE: I have a feeling that the v.* commands involving layer= is very
buggy and insufficiently tested for layer > 1
I rather strongly suspect that you are not using layers properly.
Closing the bug.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/338#comment:1>
