[GRASS-dev] Re: i.ortho.photo
Glynn Clements
glynn at gclements.plus.com
Wed Oct 22 11:25:03 EDT 2008
Hamish wrote:
> > r33944 | hamish | 2008-10-21 03:35:40 +0100 (Tue, 21 Oct 2008) | 1 line
> > remove code based on Vask_lib+Xmons; porting will happen in
> > develbranch6 then when operational be merged back into grass7 SVN
> > Isn't this backwards?
> > There's no need for i.ortho.photo to change in 6.4, as monitors (and
> > the display architecture generally) won't be changing there.
> it's just easier to incrementally test with an otherwise working suite.
> i.e. the config file setup modules will be pretty easy to fix, while the
> two i.points clones may take much longer.
> I had thought about leaving i.ortho.photo/libes/ in trunk, as that has
> some hope of being reused (ie all but ask_camera.c to be merged into
> lib/imagery/). My primary motivation was that porting fixes between two
> active branches seemed like a nightmare.
It probably will be a nightmare. Which is why I would suggest not
bothering with 6.4. Anything done there will have a rather limited
life expectancy, and may not actually help all that much for 7.0.
I suspect that the "incremental" approach will be more trouble than
it's worth, i.e. you'll end up repeatedly writing code then discarding
it.
