[GRASS-dev] Re: i.ortho.photo
Moritz Lennert
mlennert at club.worldonline.be
Wed Oct 22 11:45:28 EDT 2008
On 22/10/08 17:25, Michael Barton wrote:
> However, interactive control point
> creation/management works better if you start in a projected
> location/mapset and rectify from the xy location/mapset. This is the way
> that r.proj and v.proj work too. If there is to be work on i.rectify,
> I'd like to suggest that it be changed to work in this way (start in
> projected mapset and rectify from the xy mapset).
I don't know enough about the reasoning behind the original procedure,
but maybe it can simply take from_location/mapset= and
to_location/mapset= arguments which would allow for greater flexibility
and probably make i.target obsolete ?
Moritz
