[GRASS-dev] Re: [GRASS GIS] #273: v.example leaks memory in
db_open_select_cursor
trac at osgeo.org
Wed Sep 3 18:05:09 EDT 2008
#273: v.example leaks memory in db_open_select_cursor
Reporter: karme | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Database | Version: svn-trunk
Resolution: | Keywords:
Platform: Linux | Cpu: x86-32
Comment (by karme):
Replying to [comment:3 glynn]:
> My inclination is to apply the patch. Unlike most GRASS memory "leaks",
this one could be significant. I.e. if it leaks memory for each row
fetched, it would impose a limit on the amount of data retrieved from a
query.
Well it does not leak memory for each row fetched, but for each query. But
at the moment I am writing a v.out.osm that in the end does a query for
each line => you run out of memory quickly. It would be really nice to get
this fixed - maybe also in the stable branch? and maybe in debian/lenny?
A quick grep for db_open_select_cursor gives many hits and some of them
are in a inner loop. For example: v.out.ogr (in mk_att), d.vect (attr.c),
v.label, ...
Ticket URL: <http://trac.osgeo.org/grass/ticket/273#comment:4>
