[GRASS-dev] Re: [GRASS GIS] #273: v.example leaks memory in db_open_select_cursor
GRASS GIS trac at osgeo.org
Wed Sep 3 21:00:41 EDT 2008
  Reporter:  karme     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  6.4.0
 Component:  Database  |     Version:  svn-trunk
Resolution:            |    Keywords:
  Platform:  Linux     |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:4 karme]:
 > A quick grep for db_open_select_cursor gives many hits and some of them
 are in a inner loop. For example: v.out.ogr (in mk_att), d.vect (attr.c),
 v.label, ...
 These modules should probably be making a single SELECT statement and
 storing the results in a btree (or similar), rather than executing a
 separate query for each line.
Ticket URL: <http://trac.osgeo.org/grass/ticket/273#comment:5>
