[GRASS-dev] [GRASS GIS] #278: wxGUI: don't allow for negative
column number
trac at osgeo.org
Thu Sep 4 07:51:13 EDT 2008
#278: wxGUI: don't allow for negative column number
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
A command that requires a data table column number input, should not allow
to enter a negative value. For example, in v.in.ascii one shouldn't be
able to enter or select with the spin box e.g. z=-32 cat=-8.
Ticket URL: <http://trac.osgeo.org/grass/ticket/278>
