[GRASS-dev] Re: [GRASS-SVN] r33243 -
grass/branches/develbranch_6/lib
Martin Landa
landa.martin at gmail.com
Fri Sep 5 04:28:53 EDT 2008
2008/9/5 Martin Landa <landa.martin at gmail.com>:
> 2008/9/5 Markus Neteler <neteler at osgeo.org>:
>> OK. The problem is that
>> "vector: Vector_Library (GRASS Vector and Direct Graph Library)"
>> is no longer expanded as link. Someone just asked me if the
>> vector lib is not documented and I discovered that the link is
>> no longer generated at all. I just tried a fix but it isn't expanded...
> it should be
> <li>%vector: \ref Vector_Library (GRASS Vector and Direct Graph Library)
> see
> lib/vector/vectorlib.dox
> the page is called Vector_Library.
I reverted the changes in r33271
make htmldocs-single
builds programmer manual properly on my machine.
Matrin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
