[GRASS-dev] Re: [GRASS-SVN] r33243 -
grass/branches/develbranch_6/lib
Martin Landa
landa.martin at gmail.com
Fri Sep 5 04:24:33 EDT 2008
2008/9/5 Markus Neteler <neteler at osgeo.org>:
> OK. The problem is that
> "vector: Vector_Library (GRASS Vector and Direct Graph Library)"
> is no longer expanded as link. Someone just asked me if the
> vector lib is not documented and I discovered that the link is
> no longer generated at all. I just tried a fix but it isn't expanded...
it should be
<li>%vector: \ref Vector_Library (GRASS Vector and Direct Graph Library)
see
lib/vector/vectorlib.dox
the page is called Vector_Library.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
