[GRASS-dev] suggested temporary feature freeze for wxGUI
William Kyngesburye woklist at kyngchaos.com
Sun Sep 7 14:14:20 EDT 2008
On Sep 7, 2008, at 11:23 AM, William Kyngesburye wrote:
> I haven't tried compiling GRASS in a while, busy with other stuff.
> I thought vdigit compiled - the makefile has the correct compile
> flags to handle libgdi.
> Yes, nviz has the problem where you need to disable render.c (and
> lose nviz_cmd).  The OpenGL programming is too deep for me.
Ah.  libnviz has a problem, in nviz.h, for the AGL types.  This should
fix it (and gets a step closer to fixing the direct rendering problem):
--- include/nviz.h.orig	2008-08-12 22:19:32.000000000 -0500
+++ include/nviz.h	2008-08-12 13:03:31.000000000 -0500
@@ -128,9 +128,9 @@
      GLXPixmap windowId;
      Pixmap pixmap;
  #elif defined(OPENGL_AQUA)
-    AGLPixelFmtID pixelFmtId;
+    AGLPixelFormat pixelFmtId;
      AGLContext contextId;
-    AGLPixmap windowId;
+    AGLPbuffer windowId;
      GWorldPtr pixmap;
  #elif defined(OPENGL_WINDOWS)
      HDC displayId;		/* display context */
Now there is another error to deal with in wxpython/nviz - gstypes.h
defines X, Y and Z for (internal use only), but this causes problems
for one of the OSX application services headers.  The fix I figured
out was to include ApplicationServices.h and agl.h before the grass
headers.  This is done in include/nviz.h, but not in wxpython/nviz/
nviz.h.  Change the #include order to:
#include <grass/gis.h>
#include <grass/nviz.h>
#include <grass/gsurf.h>
#include <grass/gstypes.h>
And in nviz.i change to:
#include "nviz.h"
Now we're left with some errors in grass6_wxnviz_wrap.cpp:
grass6_wxnviz_wrap.cpp:3165: error: expected unqualified-id before ‘{’
token
grass6_wxnviz_wrap.cpp:3173: error: expected unqualified-id before ‘{’
token
grass6_wxnviz_wrap.cpp:3180: error: expected unqualified-id before ‘{’
token
These are all
static bool check(PyObject *obj) {
I seem to recall seeing this before somewhere with swig-generated
code, and I don't remember what the solution was.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
