[GRASS-dev] no way to ID table columns outside of working mapset?
Martin Landa
landa.martin at gmail.com
Mon Sep 8 12:50:12 EDT 2008
2008/9/8 Michael Barton <michael.barton at asu.edu>:
>> And, v.db.connect does accept fully qualified in grass7:
> Can this be backported to 6.4?
I think nothing need to be backported, v.db.connect seems to work with
fully qualified names.
v.db.connect -g P079214 at PERMANENT
1/VEG_TREE_BL P079214 cat /home/martin/grassdata/nc_spm_08/PERMANENT/dbf/ dbf
WARNING: 'vector/P079214' was found in more mapsets (also found in
PERMANENT).
WARNING: using 'P079214 at martin'.
1/VEG_TREE_BL P079214 cat /home/martin/grassdata/nc_spm_08/martin/dbf/ dbf
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
