[GRASS-dev] no way to ID table columns outside of working mapset?
Michael Barton
michael.barton at asu.edu
Mon Sep 8 16:44:13 EDT 2008
You are correct. This didn't seem to work when I tested it last night.
v.info -c is a problem because it does not give a list of defined
layers; you have to know which layer you want to look at and tell it.
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Sep 8, 2008, at 9:50 AM, Martin Landa wrote:
> Hi,
> 2008/9/8 Michael Barton <michael.barton at asu.edu>:
>>> And, v.db.connect does accept fully qualified in grass7:
>> Can this be backported to 6.4?
> I think nothing need to be backported, v.db.connect seems to work with
> fully qualified names.
> v.db.connect -g P079214 at PERMANENT
> 1/VEG_TREE_BL P079214 cat /home/martin/grassdata/nc_spm_08/PERMANENT/
> dbf/ dbf
> WARNING: 'vector/P079214' was found in more mapsets (also found in
> PERMANENT).
> WARNING: using 'P079214 at martin'.
> 1/VEG_TREE_BL P079214 cat /home/martin/grassdata/nc_spm_08/martin/
> dbf/ dbf
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/
> ~landa *
