[GRASS-dev] new gisprompts
Glynn Clements
glynn at gclements.plus.com
Tue Sep 9 20:14:19 EDT 2008
Martin Landa wrote:
> for wxGUI I would like to add gisprompt for 'layer' parameter (sure in
> menuform can be check parameter key, but it's not save, see the
> problem with color "none" and translations).
> for layer (read-only)
> layer,layer,existing
> for layer (to be created new vector layer)
> layer,layer,new
> for column (to be created):
> dbcolumn,dbcolumn,new
> for column (existing -- read-only mode for combobox)
> dbcolumn,dbcolumn,existing
> for color (transparent allowed)
> color,color,none
> for color (transparent not allowed)
> color,color,?
You will need to change gis_prompt() in lib/gis/parser.c to accept the
new values for the first field ("age"). I suggest making it silently
return -1 for all unknown values, rather than reporting an error.
