[GRASS-dev] Compile only wildfire modules?
Martin Landa landa.martin at gmail.com
Wed Sep 10 05:53:42 EDT 2008
hi,
2008/9/10 Rainer M Krug <r.m.krug at gmail.com>:
> Therefore I want to compile them with #define DEBUG enabled. At the
> moment, I am compiling the grass completely - but there must be a way
> of compiling only the wildfire modules (or even only r.spread)?
you don't need that, just define DEBUG variable using g.gisenv
g.gisenv set=DEBUG=5
run module
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
